08-16-2022 06:24 PM
This is going to be now my 3rd replacement with this camera. I need a solution ASAP, this driveway facing camera consistently dies after a week on 100% charge. The sunrises on driveway and sets in backyard, in Florida USA weather. Activity is very rare and have used the seen events outline to only show the seen events, not out of zone. My backyard camera has 0 issues and shows me currently lasting 3 months on 60 percent charge. I cannot even get a battery life estimation on the driveway in terms of time, I get notified when there's a day left of charge after a week being remounted. My original camera was working fine until this issue occured, now 2 replacements later still no resolution.
Please help,
Sincerely a disappointed user
08-20-2022 11:19 PM
Hi EcuazRey
Thanks for visiting the Community. I'm sorry to hear that and for the delayed response. I know how important your Nest Cam Battery is for your every day home security. No worries, let's figure this out. Is your camera exposed to extreme temperatures (sunlight, rain, dust or snow)? How does it feel (hot, warm, cold or normal)? Also, is it fully charged before you installed it? The battery drains faster in cold weather or if there's a lot of activity (even if the activity isn't saved as a clip).
Going over the steps here might help:
Let me know if that helps.
08-21-2022 07:00 AM
The camera is exposed to sunlight and rain, the driveway is where the sunrises and average Florida's summer weather is well above 90 degrees, very little shade since it's under roof eave. It was fully charged before being mounted. This was a replacement device sent from Google so it was just installed on home app.
Thanks
08-23-2022 09:47 AM - edited 08-23-2022 09:47 AM
I am sorry to hear that your doorbell isn't staying charged for long. I have an article that goes over best charging practices, and how to know how long the battery should last for. I believe that Activity Zones will help you out in this situation. You can learn more about them here. I hope you find the article helpful!
08-26-2022 10:34 AM
Best regard,
08-28-2022 03:45 PM
Hey folks!
Thanks for your help here, Brad.
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
