07-13-2023 01:11 PM
I've got multiple Nest cams and doorbells, but as of 10 days ago, my 2 Nest Cams (battery) that are outside and the 2nd gen NEST doorbell have all been showing offline. It's only those devices that are showing offline though; the rest of my Nest products (an outdoor Nest IQ cam, a 1st gen Nest doorbell that I'm using as a camera, and 2 Nest cams (wired)) are all working great.
I've restarted all three of the affected devices, but the two cameras' status lights end up doing the slow blinking white light, but don't ever switch to green. The doorbell had a green status light both before and after restarting it, but the restart doesn't seem to have made a difference as I still can't see the video in the app. For a router, I'm using a couple of Nest Wifi Pro units, and I've restarted the system a couple of times, but it hasn't made a difference.
All of the affected devices seem to be running the 1.67 OPENMASTER software, and from what I've been reading, it's that update that has caused the issues, but I don't see anything from Google to indicate that they're working on a fix, at least not officially.
07-17-2023 09:21 AM
Mine go offline constantly. Sometimes i can wake them up by plugging the power cable into them. Some people ive seen on this forum fixed there's with a reset but for some reason mine dont stay on either after a reset. No rhyme or reason though mine just drop out sporadically.
07-17-2023 03:20 PM
Thanks for posting in our Community — I'm sorry to hear that your devices aren’t working. Let’s check it out.
To fix your Nest cameras and doorbell, please follow these steps:
Let me know how it goes.
Lance
07-20-2023 03:40 PM
Hello everyone,
I’m checking in to see if you still need any assistance. Have you had a chance to try the suggestion above? If so, how did it work out?
Lance
07-21-2023 03:44 PM
Hi all,
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
