08-31-2022 02:45 AM
We got a nest cam to use as a baby monitor so we can stream it to the displays in the kitchen and living room.
Since installing it, our data usage has jumped from 600 GB /month to over 1.2 TB!
The camera is set to "high" resolution (not "max"). Is it normal to use this much data?
We also have the history turned off.
Everything I've read says it should be about 30GB and I thought the displays streamed from the camera over Bluetooth.
08-31-2022 02:57 AM
Sounds about right. If you’re continually streaming, the usage will be up there. Also, the stream is over WiFi, not Bluetooth.
As a baby monitor, the one downside with the Nest cams is you don’t get background audio when you close the app. So you have to continually stream video to know what’s going on.
08-31-2022 02:57 AM
09-05-2022 07:12 PM
Hey Lucy8984,
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue.
I appreciate the help, Rubes.
Archie
09-08-2022 07:21 PM
Archie
09-13-2022 05:50 PM
Archie
09-13-2022 08:55 PM
Thanks Archie, looks like I got the answer I needed even if it's not what I was hoping for!
09-13-2022 10:25 PM
Hey Lucy8984,
Understood. Let us know if you have any other questions as I'll be locking the thread after 24 hours.
Archie
09-15-2022 04:23 PM
Hey Lucy8984,
Archie
