Nest Door bell notification control
d-j-c
I have had to set a number of speakers to 'do not disturb', is there any to limit the speakers that announce Nest Door bell activity?
DC
David_K
Aside from using the do not disturb feature, there isn't a setting for that unfortunately. If your speaker is in the same home as your doorbell, it will play visitor announcements by default, unless do not disturb is turned on.
Get doorbell visitor announcements on a speaker or display - Google Nest Help
If this is important to you, I’d encourage you to also send this feedback directly to Google. You will not receive a response, unless Google need more details from you, however the team are still reading the feedback.
janthadeus
Hi d-j-c,
Checking in — I just wanted to make sure if you’ve seen davidking’s response. Let me know if you have further questions or concerns.
I appreciate your help, davidking!
janthadeus
It's me again. I want to check if you still need help. Don't hesitate to reach back if you do.
janthadeus
I haven't heard from you in a while so I'll be locking this thread if there is no update within the day. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the Community.
