08-12-2022 06:02 PM
I need a new metal backplate I have an issue with mine, and the doorbell won't work without one. Is there a way to order or obtain a new backplate?
08-13-2022 06:43 AM
Unlike its competitors, Google Nest does not sell any spare parts for its cameras and doorbells. If you are within the 1-year warranty, you might be able to get Google Nest to provide a replacement by contacting Google Nest Support, starting with this link: https://support.google.com/googlenest/gethelp
08-14-2022 10:14 PM
Thanks for your answer, I have tried that link but it does not let me select anything, try in another browser but same result.
08-15-2022 06:11 AM
I don't know why the link doesn't work. I'm just another customer. If you search for Google Nest Help and go to the resutling page and select "Contact us" at the bottom of any Google Nest Help page, you'll get Google Nest's method for contacting them. I don't know why it wouldn't work for you.
08-20-2022 08:23 PM
Thanks for your help here, MplsCustomer and Brad.
Just wanted to jump in here to make sure that you saw our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
08-16-2022 12:10 PM
Thank you for your patience! If you are seeking a replacement, please contact Support. FIll in the questions, Next>Next and it should give you a few options to contact Support.
08-19-2022 12:30 PM
Just checking in to see if you have contacted Support about this inquiry? Please let us know!
Best regard,
