Nest Doorbell battery not charging
Bsmith8513
I recently moved to a new home and installed the nest battery doorbell. After the first draining of battery, I attempted to charge the doorbell and no light comes on. It appeared that the doorbell charged about 10% in 12 hours.
I am using the supplied charging chord with a 10v Apple charging block. I also tried to use the smaller Apple charging block as well, to no avail. What can I do to fix this. The device has been used for 3 weeks.
Shayn
I'm having the exact same problem with mine. It's only about 6 months old and it take 3 days to fully charge it. Once it's charge it works fine. I believe it's a defective in the charging port or battery!
Trineeboyz
I’m having the same issues did you get it resolved
Hey Folks.
