Nest Doorbell will not factory reset
LPotts
I recently moved into a new home with multiple Nest products installed. I’ve successfully reset and connected to everything except for the doorbell (wired). When I try to factory reset the doorbell it does not reset. Is there a fix for this or will I be forced to buy a new doorbell?
6 REPLIES 6
I apologize for my late response. Thank you for all of your patience while waiting for a reply. I can definitely understand how frustrating your situation must be. I just wanted to make sure that your issue is addressed.
  • Do you still need help with this issue? I know that there's been a delay in response since you posted.
  • What other troubleshooting steps have you done thus far?
LPotts
The doorbell still doesn’t factory reset.
@LPotts
Are you pressing and holding down the little button with the a pin? Here is an article on the Factory Reset process.
LPotts
Yes, I understand how to reset. It just doesn’t work when I try.
LPotts
Never mind, I bought a new Nest.
Hey Folks.
