07-23-2023 04:14 AM
I have a Nest Hello doorbell. The doorbell works fine, it shows up in google home and when somebody rings the doorbell, it notifies the hubs. But... The doorbell doesn't show up in (google home) automations. If I want to select the doorbell as a starter device it doesn't show up in the list of all the starter devices I can choose.
I have checked settings, wifi, ensured the address is in.
Any ideas? Thanks
Roland
08-10-2023 05:41 PM
Hi RolandvanDijk,
Thanks for reaching out. I totally understand that this is a good feature to use with your home automation, but it isn’t available. I'd suggest you submit feedback about it, here's how.
Kimy
