07-24-2022 11:37 AM
Nest Hello says that it is offline. In the app, it shows 5 sec recordings from my doorbell, but when I tap the video, it tells me that the doorbell was offline. Google Wi-Fi point is within 5 feet of the doorbell. When I try to update the Wi-Fi, I get the NC006 or NC007 error code. My router is connected to Wi-Fi and it is the correct password. Need assistance!
07-25-2022 08:54 PM
Same!!
08-05-2022 03:18 PM
I ended up exchanging it for a new one, and it worked. Must have been a bad doorbell!
08-05-2022 03:24 PM
Hey Joelamphear,
Awesome, we're glad to hear that it's been sorted out! Give us a shout if you have any other questions.
Archie
08-08-2022 08:45 PM
Hey Joelamphear,
Archie
07-28-2022 02:55 PM
I am terribly sorry to hear that you're having this issue! I would love to assist you with this issue. If you are having issues with your Nest Cam or Nest Doorbell, I would suggest that you first start by restarting it.
Restart: Keeps all your settings, and it should reconnect to the same Wi-Fi network. This is helpful if it ever becomes frozen, has trouble reconnecting to the internet, or isn't working normally.
08-01-2022 02:35 PM
Hey there Joelamphear,
Did you have any more questions or need any additional help?
Thank you,
Jeran
08-02-2022 03:07 PM
Archie
08-02-2022 07:30 PM
No luck yet but my 18 mo old unplugged the connect and now it’s missing. I can replace this if I need to correct?
08-02-2022 09:56 PM
Hey Slim20sc,
To confirm, are you still getting the same error code while checking the live video?
Archie
08-03-2022 10:06 PM
Hey Slim20sc,
Archie
08-04-2022 11:49 PM
Hey Slim20sc,
Archie
