Nest Doorbell (wired) will not connect even though there is a green light. Help.
Scibes29
My Nest doorbell will not show a flashing blue light. I have had it for about 4 years and it just stopped working for no reason. I have tried everything. Reset/factory reset/reinstall chime. All I get is a a green light showing power so it will not connect to WIFI. I cannot find anything to help me.
21 REPLIES 21
David_K
Sounds like you've already tried some good steps. Google has a good article on how to troubleshoot this:
Troubleshoot offline Nest camera or doorbell - Android - Google Nest Help
Let us know how you get on!
Scibes29
Hey there, I have seen this article already and tried all of this. Still doesn’t work.
Scibes29
The blue or yellow ring will not come on.
David_K
If the status light is solid green, it's connected to Wi-Fi and working normally. The light ring doesn't turn on unless the doorbell senses motion or the button is pressed.
Nest camera and doorbell lights and sounds - Google Nest Help
Can you see the doorbell in the Google Home app?
Scibes29
When I press the button it does not light up. When I try connecting to the camera in the app it will not connect. Says to reconnect the chime because power is not getting to the camera. I know there is power because of the green light. I originally deleted the camera from the app because it wasn’t working so I was going to reconnect it. But then I ran into all these problems.
David_K
What are the specs of the transformer you have? It needs to be rated for 16-24 V AC, 10-40 VA to provide enough power.
Upgrade your transformer for Nest Doorbell (wired, 2nd gen) - Google Nest Help
Scibes29
I’m not sure but it has been running fine for over 3 years and have never had this problem. It just stopped all
of a sudden.
David_K
Okay so you have gen 1 not gen 2 as you selected, as that was only released in Oct 2022, not to worry. It definitely sounds like a power issue so I'd suggest:
  1. Check that your doorbell is still wired correctly.
  2. Check that the wires and your transformer is still providing the required power.
If you're not comfortable doing this, you may need to contact a Nest pro or a local electrician for help.
Scibes29
I will look into this and let you know.
Thanks!
zoeuvre
@Scibes29, thanks for reaching out to us. I hope you've already gotten the answer you are looking for. Please let us know if you still have questions or concerns, as we'll be willing to assist you more.
I appreciate your help, @David_K.
Scibes29
I am going to look into the transformer but just haven’t had time yet. Hopefully this next weekend. Will keep you posted.
zoeuvre
Hi Scibes29,
Alright! Sounds like a plan. I'll keep this thread open, but please be advised that as Community Specialists, we occasionally do a bit of housekeeping to keep the conversations in our community fresh and relevant. This includes locking threads after a period of inactivity.
Scibes29
Any other ideas? Still stuck.
Lance_L
Hey everyone,
@Scibes29, thanks for getting back to us and for sharing what you’ve done to have your concern resolved.
Let’s try the troubleshooting steps below:
  1. On the Nest app home screen, tap Settings.
  2. Select Home Info, then Home Wi-Fi help.
    1. Note: If you don't find Home Wi-Fi help, you'll need to remove your camera from the app and add it back with new Wi-Fi information. You'll lose your video history, so make sure to save any important video clips before removing your camera.
  3. Select the device you want to update.
  4. Tap Start > Update settings.
  5. Follow the on-screen instructions. Scan the QR code on the back of your camera when prompted.
Let me know how it goes.
I appreciate the help, davidking and zoeuvre.
Lance
Scibes29
I am unable to update this way because the camera has already been taken off the app and I cannot reinstall it without wifi connecting to it. So when I go settings/homeinfo/homewifihelp my other nest products show but not the doorbell camera.
Charlie
Lance_L
Hi Scibes29,
I gotcha. In this case, follow the steps below:
  1. Unmount the doorbell.
  2. Hold down two buttons on your doorbell for about 10 seconds:
    1. Hold down the reset pin on the back (insert the release tool or paperclip into the hole near the top).
    2. At the same time, hold down the big doorbell button on the front.
  3. Your doorbell will chime, and its light ring will start spinning blue, then flash yellow, and then all the lights will turn off. Release the two buttons.
  4. The factory reset is complete when your camera chimes and the light ring starts slowly pulsing blue.
  5. Make sure the phone is on the same Wi-Fi network as the selected network for the Nest device.
  6. Bluetooth should be enabled, but it should not be connected to any Bluetooth devices. Disconnect any Bluetooth devices paired to your phone, such as earbuds, smartwatches, etc.
  7. Cellular data should be turned off.
  8. If you have an iOS device, tap Settings > Privacy and then Local Network. Turn on Local Network Access for the Nest app.
  9. Start adding the doorbell to the Nest app.
Keep me posted.
Lance
Scibes29
I have tried this already through troubleshooting articles. When I put the pin in and hold the big button at same time nothing happens. It never chimes. I have tried this ten or so times even holding for up to a minute or longer.
Lance_L
Hi Scibes29,
I’m sorry to hear that the steps you took didn't work. I’d be happy to look into this for you. Please fill out this form with all the relevant information, and let me know when you're finished.
Lance
Scibes29
Filled it out.
Thanks
Keep me posted?
Lance_L
Hey Scibes29,
We got your form — thanks for filling it out. Our team will reach out to you via email to further assist you. Also, please be advised that this thread will be locked after 24 hours.
Lance
Scibes29
I checked the wires. All good. I tested the transformer and I’m getting good power 20.5volts consistently. Im baffled as to what is going on? Any other suggestions or is this unit done?
