Nest Hello, (Wired doorbell) boot issue solved?
Stickan
I have run into the boot loop issue with my Nest hello. It has been running well for over a year but now it doesn't start up. The blue light blinks twice and then the green light flash and it restarts with the same procedure. I have found several threads describing the same problem but no solution or official way forward with the troubleshooting.  Does anyone have an idea on how to proceed except from buying something else?
13 REPLIES 13
JillG
I have the same problem with my Nest Hello and also responded on the other related thread(s). I was unable to get a warranty claim so I just turned off the indoor chime. Now the Hello sends notifications to my Google speakers and displays without rebooting itself
Unless your device is within the warranty period there won't be a replacement. I use the workaround with the speakers and some others replaced an internal battery within the device itself.
Wish I had better news.
Stickan
Tnx, for sharing. I have a open support case with google and hope they will be abele to give me a way forward here. Mine doesn't even boot up so it is more or less bricked as is.
JillG
Ugh!
Support would be your best route for resolution. They will likely ask you to remove and reinstall the Hello.
If you want to give a full reset a try here are the instructions: https://support.google.com/googlenest/answer/9252162?hl=en#zippy=%2Cnest-doorbell-wired
Best!
janthadeus
Hi folks!
I appreciate your help, JillG.
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue. if you have other questions and concerns. Feel free to let me know.
janthadeus
Just checking in to see if you still need help with this. We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Stickan
Thank you for your engagement. I haven't been able to solve the issue and I strongly believe it is an issue with the hard-coded software, it will not start up in any way, just loop in the boot sequence. I chose Nest/google in the first place for quality reasons but need to reconsider that for future investments. I have 12 devices and this is the first that fails/breaks but it is annoying that it is just some code that doesn't work.
janthadeus
Hi Stickan,
Thanks for trying and I appreciate your efforts. Let's dig deeper into this. Has there been any recent power outage in your area? Where is the device installed? Have you checked if the wires aren't connected securely into the doorbell. Also, has it been exposed to direct sunlight?
aatienza
Hey Stickan,
I appreciate the help, JT.
Archie
janthadeus
Thanks for chiming in, Archie.
Just wanted to jump in here to make sure that you saw our response. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Well, you haven't been added anything of value more than I can't get any help if I don't have a guarantee left.
I give up on this.
janthadeus
Hi Stickan,
Don't give up on us yet. I know how you feel about this and we appreciate your efforts.
Going over the steps here might help:
  • Ensure the wires at the back of your Nest Hello doorbell are securely seated on its screws.
  • Remove your Doorbell camera from the wires, look for a USB cable then connect it into a laptop computer to see if the ring light goes blue pulsing.
  • When you see the light pulses blue and the live video becomes available put it back to the wall mount.
Let us know how it goes.
janthadeus
Hi Stickan,
It's me again. I want to make sure you're all good — how did the steps go?
janthadeus
Just wanted to jump in here to make sure that you saw my response. Please let me know if you have any other questions or concerns as I will be locking this in 24 hours.
