Nest Hello not reconnecting to Wifi
Klo
Not sure if this is the place to report this. In case it is I’ll give it a shot here.
I think it’d be great if in the upcoming software updates, the nest hello would try to reconnect to wifi once the connections has been disconnected. I have wifi repeaters and they are set up to automatically update the firmware and to reboot after upgrade. When this happens my nest hello looses connection and I have to reboot it manually to re-establish the connection to Wifi - which is very unpractical if I am not at home. A fix to change automatically reconnect would therefore be great.
Hey Folks.
