07-15-2022 02:56 PM
Whenever i open my live feed it buffers for a while then says live feed unavailable. Ive tried on different devices. Also the quick responses arent working, it says something went wrong. Ive restarted and factory reset my doorbell and still having the same issue. Does anyone have any ideas or had the same problem
07-18-2022 12:29 AM
I spoke to someone at Google yesterday, it's now fixed. I was asked to create a new home in the Google home app and add the doorbell there. Definitely not ideal as i had to delete everything in my original home and install it again, which required me to clime ladders to scan the nest cams i have to add them back into the nest app after deleting them. But at least it works perfectly now.
07-15-2022 04:08 PM
Just bought a doorbell (battery). Having the same problem
07-15-2022 09:28 PM
+1 DOA, sending back to Amazon.😡
07-16-2022 12:06 AM
Just woke up and its now saying its offline, i think mine might need returned too.
07-18-2022 12:29 AM
07-18-2022 12:36 AM
Tihis is realy stupid solution
07-18-2022 09:20 AM
I agree, it took all day too. It should have worked properly as soon as i added it but there you go.
09-09-2022 05:02 PM
I'm dropping by to ensure that everything is covered here. I hope that sheds some light on the issue.
Archie
09-13-2022 05:15 PM
Archie
09-14-2022 06:30 PM
Archie
