09-24-2024 08:35 PM
I own and use 7 Nest cams. 6 of them work well.
The issue I have with 1 nest cam battery model is the audio from the microphone is inaudible. I am unable to converse with people using the camera. They can hear me when I talk, but I can't hear them. I have also checked the recorded video of the events and the audio from the microphone is inaudible there as well (but my voice can be heard speaking through the app). I am using the Google Home app on my S24 Ultra. I have also tested with another S24 Ultra and an S22 Ultra. I have toggled the microphone on/off. I have factory reset the camera and set it up again. Problem still persists.
What are my options for getting a functioning camera?
09-25-2024 08:05 AM
You could try contacting Support:
09-25-2024 08:56 AM
Sounds to me like the camera has malfunctioned. If it is less than a year old then Google will likely replace it at no charge. Other wise you are on your own. Maybe buy a used on from eBay to save some money.
09-30-2024 01:36 AM
I did not realise there is a 2 year warranty on these cameras (in Australia). Google sent out a replacement. The new camera works as intended.
09-30-2024 08:30 AM
Thanks for the update. That is great news. Nice that you get 2 year warranty in Australia).
