Nest cam with Floodlight
Davey172
I have just installed a nest cam with floodlight, camera working well and one of the floodlight lamps but the other won’t work. Any ideas, is this a simple fault on the unit? I must add that this is my second install and nothing has been done differently. Has anyone else had this issue or has any ideas as to what may be the issue? Thanks
BG
Silver Product Expert
Sounds defective, but very odd that this is your second one that did this. None of mine had this issue, and I have not heard of this issue yet. I would try replacement again. If the third one does the same thing, it is not the floodlight.
Davey172
Thanks, however my first install is working fine it’s just this second one, sorry if this was not clear. I am leaning towards a faulty unit so I ll speak with the retailer. Thanks for help.
Thanks for your help, @BG!
Hey Folks.
