08-07-2022 02:41 PM
Nest cam(battery)is great but has little trouble about stream.
First, audio speakers and mic looks working g good from camera side.
However, it is very low volume on my cell phone because it is not coming through loud speaker but ear piece speaker. There were no option for change this setting.
Second, audio conversation isn't possible in my nest hub. There were no mic button if I turned on the stream via nest hub.
If there is way to solve this problem, please let me know
08-12-2022 05:23 PM
Hey Nocheol,
I’m sorry you’re having trouble with this. No worries, we'll check this out. What's the make and model of your phone? When did you first encounter the issue? Does this happen often? About the audio conversation on your Nest Hub, you'll have access to the live view and Talk & Listen functionality in the Google Home app. If you’d like to access the full set of Nest Cam features such as activity notifications, Nest Aware features, etc. Learn more here.
Archie
08-12-2022 06:03 PM
I am using Samsung galaxy s22 ultra.
About nest hub, I couldn't find out any information to solve the problem.
Even 1st generation nest door bell support mic through the nest hub but 2nd generation nest cam couldnt? I cant believe that. I am in the 30 day trial nest subscriptions and even regardless the subscription this is basic. Please let me know what am I missing
08-22-2022 04:58 PM
Hey Nocheol,
I understand. Could you check if your Nest Hub is muted? Try to restart your Nest Hub by unplugging it from the power outlet to refresh the connection. If that doesn't work, resetting it to its default settings might do the trick. Learn more here.
Archie
08-25-2022 10:48 PM
Hey Nocheol,
Archie
08-26-2022 07:42 AM
It does not fixed by reset.
I have 3 nest hub and all same. I can't believe it is not reproduce in your side or you just give me back automatic answer?
08-26-2022 10:46 AM
08-30-2022 08:37 AM
Best regard,
08-31-2022 08:52 AM
08-31-2022 08:57 AM
Nothing solved. I have working in the IT Industry for a long time and it was very surprise how google handle there bugs.
First step is try to follow customers issue and procedure. It is 100% happened and not only one device but 3 device has same problem. It should be fixed within 24 and have to release new SW within 3 month but google just keep pushing to customer give up. I don't need more assistant. So disappoint google customer service.
