New Spectrum WiFi - Nest cameras won't connect
NancyFF
I have a new Spectrum Modem and WiFi (separate).  I have successfully (easily) connected Ipads, Android phones, Smart TVs, wireless printers, and a Ring Doorbell to the new Router.
I have four Nest indoor cameras and one outdoor which refuse to work with the new router.  I get error messages C225 and C325.  I have been working on this for the past four hours to no avail.  I see that others on these forums have had similar situations.  Has anyone been able to resolve this or do I now have $1K of paperweights?  TIA
18 REPLIES 18
JillG
Hi NancyFF,
See this Nest Help page for information about those 2 error codes. Troubleshoot Nest camera and doorbell setup messages - Google Nest Help
C225 ∙ C325
This can happen when you’re trying to connect to a hidden Wi-Fi network, and you entered the information manually. You may have picked an incorrect security type for your Wi-Fi network.
Troubleshooting
Note: If you’re not comfortable checking your network settings, contact the person or service provider who set up Wi-Fi in your home to do it for you.
Double check your Wi-Fi network’s security type. For example, this error may appear if your Wi-Fi network’s security type is WPA but you selected WEP during setup.
In the app, tap Try again. Re-enter your Wi-Fi information. When prompted, select the correct security type for your Wi-Fi network.
If you’re still having trouble, you can try temporarily un-hiding your Wi-Fi network so that your camera can find and connect to it automatically. Then, when you’re ready, you can hide your network again.
NancyFF
JillG,
Thanks for your reply, but I have already been through that.  My router's security is WPA2 by default.  Network is not hidden.  I have had no problem connecting any of my other devices. This should have been a piece of cake too.
Any other thoughts? Thanks in advance!
I am wondering if
Thanks for your help, JillG!
rwturner
Brad - it is Robert with the same problem.  Do you know how to resolve it?
Error code C325
@rwturner
I would suggest following the information that @JillG has shared above. I think that would help explain the issue a bit better.
JMagoo7
I'm having a similar issue with my new spectrum router/wifi. I get the error code C104. I read the other thread but my router does not have the option to turn off 5G. It is ridiculous if Google does not have a fix for this. Please let us know how we can get our cameras reconnected. Thank you
NancyFF
Thank you but that information did not help nor solve my problem.
rwturner
Solved this yesterday.  Needed to buy a Google WiFi dual band router from Best Buy SKU6468004 and plug this into my Spectrum router so that i could now set up two networks in my home,  The camera is tied to the Google router so now we have a Google camera talking to a Google router and it is obviuosly a marriage made in heaven.  My Google router was a refurbished one and got it for US$55.00,  Problem solved,
NancyFF
So you plugged the google router into one of the ethernet ports on the Spectrum router?  TIA
rwturner
Yes
NancyFF
Great! I've already placed my order. So happy I'll be able to use my Nest cameras again. Thank you rwturner!!!
JMagoo7
Thank you all! I ordered a router as well - fingers crossed !
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey folks.
Not sure what to tell you about the Dropcam issue, maybe restart it or factory reset it and see if it works properly again. Also, verify that it is still connected to your account. I do not know anything about spectrum wifi, so I wouldn't be much help at all there. I'd suggest you check out the wifi forums \for more info.
NancyFF
My Google wifi arrived yesterday.  The Good News - I was able to connect my Nest outdoor camera that I purchased in 2021.  The Bad News - My indoor Dropcam indoor cameras that were purchased in 2014 would not connect.  Thank you to @rwturner  for all your help.
rwturner
Glad it was of some help.  My outdoor camera was the one that I was addressing with this solution and am pleased that it worked for you as well.
NancyFF
If anyone has any luck with connecting their old Dropcams to the Spectrum wifi6 router, please let me know how you got them to work.  I am sad that such good cameras are now useless. TIA
Hey Folks.
