New battery Camera Smartthings
pebblebed
I want to turn on a set of lights (20 Off) on movement from Camera. But there is no integration with Smartthings. Will / When the battery outdoor cam added to the smartthings compatibility list?
Or please advise how to achieve this without smartthings integration. It needs to be relay control, not single bulb such as hue
Thanks
7 REPLIES 7
Jesperr
Hi, the doorbell battery of google also doesn't work with Smartthings, Google Dev still need to create the link between the new cameras and smartthings
pebblebed
Thank you @Jesperr
@Brad Do you have a view of when this will happen for the battery outdoor/ indoor cam?
Hey there folks.
You can try to connect them together, but I am not sure if the new cameras work with SmartThings as I have never used it myself. But you would probably need to Factory Reset them to add them in. Please let me know if you need further assistance.
Eric_B
Have a great day!
Eric
pebblebed
Hi @Eric_B
This question has not been answered.
Ok the integration does not work today, but the second part of the question was when will it work, which has not been answered
Thanks
@pebblebed
We do not have any form of ETA to provide you with. Thank you so much for bringing this up to my attention! I like that idea, and I could see how it could be helpful. I will go ahead and submit this feedback forward for you. Thank you for all of your patience.
Please let me know if you need further assistance on this issue.
Hey Folks.
