Next Doorbell (battery) cracked lens
zekecarder
I closed our front door the other day and our Nest Doorbell (battery) fell off its mount and the lens cracked.  Is there a way to replace the lens?
6 REPLIES 6
@zekecarder
Google Nest does not sell spare parts, but you should be able to contact Google Nest Support for a replacement doorbell if it is within the 1-year warranty. The doorbell shouldn't just fall off of its mount (though other customers have also reported this).
To reach Support, you need to start with this link; depending on your location and time of day, you may have contact options:
Thanks for your help, MplsCustomer.
We're sorry to hear that. Let's check this out — could you fill out this form so we could further investigate?
janthadeus
Hi zekecarder,
We haven't received your form. Were you able to fill it out? Do you still need help?
Thanks for following up.  I was able to talk with customer service and am going through the warranty replacement process.
janthadeus
Hi zekecarder,
Sounds good! Glad to hear from you. Give us a shout if you have any questions.
janthadeus
It looks like we can consider this one complete, so I will be locking this in 24 hours if we won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
