Problems setting up new doorbell
TehStoneMan
I am trying to set up a new doorbell, but when I try to set it up through the Home app, it tells me to use the Nest app, and when I try the Nest app, it tells me to use the Home app.
Is there any other method I can try?
2 REPLIES 2
TampaTec
Silver Product Expert
might be an update issue. try going into app store then update both apps, but if its a software error you can restart the phone to clear out any bugs.
TehStoneMan
Didn't work. Is it possible that my phone is too old? Galaxy Core Prime SM-G360G
