04-22-2022 12:33 PM
How after all the questions and complaints is there no solution to missing or getting replacement mounts for the nest cam (battery) . Ive seen hundreds of posts on google and no solution to getting an original mounting kit for my two cameras. HAs anyone been able to aquire one or maybe 3d print something then add a powerful earth magnet to, i see a potential here for someone to corner this market that Google has dismissed. Does anyone have a solution. Yes im out ofwarranty so thats not an option.
05-20-2022 09:16 AM
I apologize for my late response and thank you for all of your patience while waiting for a reply. I understand how frustrating your situation must be, and I hope we can find a solution together. Do you still need help with this issue?
05-24-2022 01:20 PM
Well a couple of magnetic mounts would help lol
05-25-2022 09:30 AM
Thank you for your patience. We do not process these requests in the Nest Community Forums. If you are seeking a replacement, please note that unless the device is under warranty, we cannot issue a replacement.
Please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number.
05-30-2022 08:29 AM
Hey Folks.
