Ring doorbell wireless
hayleyjluttman
Can you connect the ring doorbell to your google home nest? Need help to set up if you can as I’m unsure
DDW
You can add it to Nest and Home, note they are two different apps.  Note that Nest will require a subscription if you would like to have a history of visits to your front door.
Just checking in to see if you still need assistance with this issue.  We'll leave this topic open for another 24 hrs in case there are any follow up questions or comments. Please let me know if you need further assistance.
Hey Folks.
