03-13-2022 06:28 AM
Good morning.
For Google Nest cam 2nd generation
wired (White) i am looking for wall support replacement. I don't find anywhere. Can anyone suggest where buy at a good price? Thanks
03-16-2022 02:49 AM
No answer?
03-21-2022 11:29 AM
03-21-2022 11:42 AM
Sure that i need help. If no one answer the question is active.
03-25-2022 09:11 AM
Thank you for your patience. If you are seeking a replacement, please first fill out this form so Support can collect some important information from you. Once the form is submitted, you will have your case number. Please be aware that this thread will be locked.
