Talk and listen not working as well as responses
Baronoli
Bit of a weird one, but my nest camera(Battery) and Doorbell (battery) are not outputting any of the talk and listen sessions or quick responses through the speakers on the devices.
I've tried on my Pixel Pro 7 and a Pixel 2 XL, on the beta version of the app and the normal version.
Microphone permissions are there, so not sure what's happening
The doorbell is also plugged in and powered, no chimes as we use hubs.
Everything else seems to be fine.
I tried it at another home I have setup and the talk and listen works fine on the same model of camera
9 REPLIES 9
Jimmy_J
this has been a known issue for some time.  google's answer?  try it on another phone.  umm... I don't keep extra cell phones just laying around.  what a joke.
Baronoli
Just noticed as well the "Ding dong" when pressing the bell doesn't come out of the physical doorbell either....
My other camera is fine now, just hte doorbell playing up.
EmersonB
Hello everyone,
@Baronoli it's us again. I'm bumping up this thread to ensure that everything is covered here. To know more about this, we'd like to confirm, did this issue occur out of the box? If not, when did you notice the problem? Is the audio issue persistent or intermittent? If intermittent, how often does it happen? Has the camera suffered any drops or impacts?
Give these steps a try:
  • Check your Google Home app or Nest app permissions:
  • Go to your phone’s Settings> apps> Google Home app or Nest app> permissions, and make sure the microphone is enabled.
  • Test if the device’s microphone is working.
  • Open your default voice recorder app or any other app that uses your mobile device’s microphone and test the device’s microphone on your app.
  • Check if your device is connected to a bluetooth device that may be serving as the microphone.
You may check these links for your reference.
Talk and listen with Nest camera or doorbell
Change Nest camera and doorbell audio settings
I appreciate the help, Brad.
Hi Ebedia,
The door has been installed for just over 1 year, it did work before and not sure when it stopped, but someone pressed the doorbell and I tried to talk and they couldn't hear me, nor did my quick respones come out. It is constantly not working for push to talk, responses and the bell doesn't even make a "ding dong" sound when pressed. It is wired and never been dropped.
I have tried the app settings. I have 2 other homes I'm a member of and the doorbells work fine on them for responses. It makes me think the doorbells speaker is defective if it doesn't even make a "ding dong" or a "quick response" from the speaker.
I have tried a factory reset, restarting it and reinstalling the app/doorbell and nothing is fixing this 😞
Thank you
EmersonB
Hi Baronoli,
Thanks for getting back to us and for sharing with us the steps you've done. I'm sorry to hear about your experience on your Nest doorbell (battery). We'd be happy to take a look into this for you. Please fill out this form with all the needed information. Let me know once you’re done.
EmersonB
Hello Baronoli,
I wanted to follow up and see if you were able to fill out the form? Let me know if you have additional questions.
Hi Ebedia,
I ended up contacting support via a live chat and arranged an RMA - thanks for all of you who helped 🙂
janthadeus
Sweet, we’re glad to hear that! As we got our resolution here, I'm going to mark this thread as complete. I'll be locking this thread if we won't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Thanks for the help here, Brad and Emerson.
