12-04-2023 06:18 AM
I have the nest app on my android phone. Can I view my cameras on my Window based) SurfacePro tablet?
12-04-2023 08:53 AM
Hello, I'm an end user like you. Just like on your computer you should be able to go to the browser on your Surface Pro and go to the website "https://home.nest.com/". Log in with your same login and password on your Nest App and you should be good to go. If instead you are using the GOOGLE HOME app on you phone then you would go to home.google.com instead.
12-04-2023 08:53 AM
