Wifi connection issue (nest cam battery)
icclassd
Hello
I recently bought google nest cam battery version.
i would like to connect to 5Ghz so that I have better bandwidth usage over some corners.
I want to set 5GHz wifi within the same network. I spent so much time and tried many ways that I can think of, but I was not able to find a way.
1) Is there a way to see which network/Ghz that a specific device is connected to?
it is easy to see some of nest devices but I dont understand why some devices like these cams do not provide such options. by the way, is there a way to connect these devices to nest apps?
I like the nest app much better than google home.
2) Once I see which network/Ghz is connected to my device, can I change wifi network connection? It is totally unknown and fairly frustrating that it wont let me choose a better connection.
thanks in advance.
0 REPLIES 0
