03-13-2023 12:30 AM
Is a AC 18V 500mA 9W transformer suitable for the wired google door bell
03-13-2023 02:35 AM - edited 03-13-2023 06:32 AM
It seems you're talking about an indoor AC/AC power adapter.
There is not a lot of documentation around Nest Doorbell (wired, 2nd gen) working with AC/AC adapters.
Just make sure your adapter meets the requirements here: Check Nest doorbell compatibility - Google Nest Help.
03-15-2023 07:24 PM
The problem I have is converting the VA? My existing converter was for a Arlo door bell
03-16-2023 03:51 AM
9W should be good. See for instance this one working with a large range of doorbells, including the Nest Doorbell (wired) / Hello having the exact same requirements as the Nest Doorbell (wired, 2nd gen): 9W Power Supply Charging Adapter Charger For Transformer Ring Video Doorbell 5M | eBay
03-18-2023 02:28 PM
@JC80, thanks for posting here in the Community. The Nest Doorbell (wired, 2nd gen) has higher power requirements than most doorbells. You need a transformer that is rated for 16-24 V AC, 10-40 VA to provide enough power to your Nest Doorbell. If you've already installed your Nest Doorbell and you see a blinking yellow light on the front, your Nest Doorbell isn't receiving enough power. Hit this link for more information.
I appreciate the help, alex2023.
03-19-2023 11:58 PM
Thanks for the info.
it helps a lot.
im looking into the battery google door bell as I read that it can be also hardwired as an option. What power would this require?
thanks again
03-20-2023 07:34 PM
Hey JC80,
You’re welcome! The Nest Doorbell (battery) requires a voltage of 8 to 24 VAC and power is 10 VA. To learn more, have a look at this guide: Check Nest doorbell compatibility.
I appreciate the help here, alex2023 and Emerson.
03-24-2023 12:27 PM
@JC80, I'm dropping by to ensure that everything is covered here. How's it going with your Nest Doorbell? Were you able to read the information and check the link that JT has shared? In case you have an update, you know where to find us.
Thanks for lending a hand, JT.
03-25-2023 04:16 PM
Hey JC80,
Just one quick final check in here since activity has slowed down. We'll be locking the thread in the next 24 hours, but if you still need help, we would be happy to keep it open. If there's more we can do, just let us know.
