google nest doorbell low audio
pman77
How do you adjust the audio volume on the google nest doorbell. When someone is talking to to me and they are next to the speaker the volume is very low. I have looked at the settings and cannot find a way to increase the audio. This issue makes the camera almost unusable.  The other issue is the camera also seems to pickup lots of wind noise which is interesting since the speaking volume is extremely low.
EmersonB
Hello pman77,
Thanks for reaching out here in the Community. We understand what you’re referring to and we wanted to help you with this.
Give these steps a try:
  • Make sure that your Nest Doobell’s microphone is on and that audio settings are correct. Newer Nest Cameras and Nest Doorbells let you adjust the speaker volume:
  •  In the Home app :  Tap Favourites or Devices  touch and hold your device's tile Settings Nest settings icon Audio and use the slider to adjust the volume. You can also turn the microphone on or off, and switch audio recording.
  • In the Nest app, tap Camera Settings Nest settings icon Microphone and turn the microphone on or off, or adjust the sensitivity.
  • Older Nest cameras and doorbell speakers have a fixed volume. If needed, move your camera closer to where people will be when talking.
  • For more info and instructions, go to Change Nest camera audio settings.
