06-16-2023 08:29 PM
i have a brand new nest door bell wired 1st gen but i was unable to connect to my google home.
i have linked it to my wifi using the nest app. the light on my door bell is green.
06-17-2023 03:53 AM
When you install the Nest Doorbell in the Nest app, the doorbell should automatically appear in the Google Home app if you’re using the same Google account in both apps, using the same home structure, and have assigned the doorbell to a room in the Nest app. If any of that isn’t true, you’ll need to go ahead and fix those issues to see if you need to try the steps below at all.
Assuming all of the above is true. try these steps:
This forces the two apps to sync and your doorbell should now appear in the Google Home app.
06-19-2023 03:17 PM
Thanks for reaching out. I just want to check if you were able to try the troubleshooting steps that have been provided above. Please let us know how it goes.
I appreciate your help, @David_K.
06-22-2023 03:39 PM
Hi mackeral,
06-26-2023 09:30 AM
Hey mackeral,
