Chromecast no sound !!
okayycaroo
Hi guys need some help, I’ve had my chromecast for around 3 years now and works perfectly fine. I got Disney plus a few weeks ago and had to change the sound settings (stupidly remembering how I did it) and I had just gone to switch back to watch my usual (twitch) and the sound isn’t working, I’ve done everything I’ve reinstalled, I’ve rebooted, I’ve checked the tv settings and nothing is working! Please help
7 REPLIES 7
JenniferV
Hi okayycaroo,
Thanks for reaching out and sorry to hear about that. Let's sort this out.
A few questions: What type of Chromecast device do you have? Does the issue only occur when using the Disney Plus app and Twitch or across all apps? Is the TV connected to an external receiver, soundbar, or speakers?
Give these steps a try:
  1. Check if the Chromecast is connected to the power outlet and if the TV is on the right input.
  2. Confirm that the device you uses with Chromecast is not muted (Examples: TV, mobile device, etc.)
  3. Confirm that the TV, sound bar, and/or receiver is not muted.
  4. Use a different HDMI device on the same HDMI input and check if audio works.
  5. Use a different HDMI input.
  6. Unplug Chromecast and plug it back in.
  7. Unplug TV and plug it back in.
  8. Check if the no audio issue occurs from all apps or only when casting certain websites.
  9. Cast the same Chromecast device on a different TV (if possible).
  10. Perform factory reset. Here's a guide: How to factory reset your Chromecast.
Let me know how it goes.
Jennifer
JenniferV
It's me again. I want to make sure you're all good — how did the steps go?
Jennifer
JenniferV
Hi okayycaroo
Just checking in to make sure that you've seen my response. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Jennifer
Hello Jennifer! I’m afraid i have a super busy schedule and am not always able to reply as fast! But none of these worked, it only changed when I changed the sound settings with Disney plus but I’ve done the settings back and it’s still the same, my tv works as normal with sound but it’s just not seeming to work on anything I’ve tried! Anything else you’d suggest?
Thanks for the help!
JenniferV
Hi okayycaroo,
Understood and thanks for getting back to us. Is the issue only happening with Disney plus and Twitch or across all apps? If this is isolated with these two apps, please reach out to the app developer for additional help.
Jennifer
JenniferV
How's it going? Still need help with this?
Jennifer
JenniferV
Hi okayycaroo,
I haven’t heard from you in a while so I'll be locking this thread if there’s no update within 24 hrs. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
Jennifer
