01-29-2022 01:08 PM
Going through the entire setup we all get an error that the Chromecast isn’t working with our phone. It’s a new 2.4/5ghz. I have it set up within three feet of the router. All of us try on different iphones with local network enabled and it says it’s set up as if the wireless network work and everything, it just won’t work with the actual phones. It used to work with this internet provider and setup.
04-29-2022 01:22 PM
Hi Diad3131,
We hope you were able to get the help you need but if you're still having trouble, you might want to check out this link. If the issue persists, feel free to submit another post and provide as many details as possible so that others can lend a hand. Hope this helps!
Kind regards,
Alex
