Chromecast won't connect and keeps freezing
ash-maffs
I have issues casting from both chrome and apps - I've tried rebooting and factory resets multiple times. When it does actually connect the video will play and then freeze for long periods of time.
JenniferV
Hi ash-maffs,
Thanks for reaching out and for being a step ahead of us. I'd love to dig deeper into this.
A few questions — is the casting device's power saving mode turned on? How close are the devices to each other? Are there other apps that actively run on the device? When did the problem start?
Give these steps a try:
  1. Disconnect from Chromecast, then recast.
  2. On the casting device, toggle Wi-Fi off and then on.
  3. Close any resource intensive apps that are open.
  4. Turn off power saving mode.
  5. Check the proximity of the devices.
  6. Confirm that the casting device meets the minimum system requirements to support casting. Check here: Minimum system requirements to cast from Chrome and Mobile devices operating system (OS) requirements.
  7. Make sure the Google Chrome browser, device OS, and Chromecast software are updated.
Keep me posted.
Jennifer
JenniferV
Hi ash-maffs,
Just checking in to make sure that you've seen my response. Please let me know if you have other questions or concerns as I will be locking this in 24 hours if I won't hear back from you again. Feel free to start a new thread and we'll be happy to help.
Jennifer
JenniferV
It's me again. I want to make sure you're all good — how did the steps go?
Jennifer
