Help! Constant restart
juleskiiii2013
Recently I have been having a lot of issues with my Chromecast. Out of no where it reboots itself. It will do this multiple times everytime have to go back and start all over.
2 Recommended AnswerS
finch5
Product Expert Alumni
I would recommend doing a factory reset by following these steps on your 2nd Gen Chromecast:
From the Google Home app
Note: This option is only available if you still have access to the network your Chromecast was set up on.
  1. Open the Google Home app
  2. Touch and hold your device's tile.
  3. At the top right, tap Settings
    >> More>> Factory reset >>
     Factory reset.
From the Chromecast device
While the Chromecast is plugged into the TV, hold down the button on the side of the Chromecast. The LED should begin to blink orange. When the LED light turns white, release the button and the Chromecast should then restart.
Finch
Roberto1
I had the same issue with my recently bought Chromecast TV 4K. Until I replaced the bundled power adapter
finch5
     Factory reset.
Finch
Roberto1
JenniferV
Thanks for the help here, finch5.
Roberto1, glad to hear that this has been sorted out and thanks for sharing your resolution in the Community. Give us a shout if something comes up — we're here to help!
juleskiiii2013, we hope that helps. Feel free to let us know if you still need assistance or if you have other questions and concerns.
Jennifer
Jeran
Hey there juleskiiii2013,
Do you have any more questions or need any additional help?
Thank you,
Jeran
Jeran
Hey everyone,
Does anyone have any more questions that we can address? If not, I'll go ahead and lock up this thread in 24 hours.
Just checking up,
Jeran
