11-28-2023 11:23 AM
What is the C wire voltage range acceptable for a Nest thermostat?
12-02-2023 05:40 AM
Below are the ranges that the Voc, Vin and Iin should stay in during normal operation. There are different Vin and Iin values if you have a common or C wire in your thermostat.
Nest Thermostat
with or without C wire
Nest Learning Thermostats & Nest Thermostat E
With C wire
Without C wire or with power connector
