03-12-2025 05:14 AM - edited 03-12-2025 09:52 AM
Hello, I also restored it to factory settings and following the following steps I was able to reconfigure it, I managed to broadcast from the mobile to the TV again, but the image from the mobile is only partially displayed, at least I was able to reconfigure it and now I just have to wait for the update.
If you have restored the factory settings, follow the steps below. If you have not restored it, skip this step and go directly to the process with the free code app.
First of all, you need to change the date on your mobile phone to a day before March 9, 2025. From here you can reconfigure the Chromecast.
Then follow the following steps to be able to broadcast again
IMAGES OF THE PROCES
This workaround forces open the Cast Debug settings page and lets you enable the Bypass Device Auth option (i.e., it allows you to turn off device authentication), partially fixing the issue. You should now be able to cast from apps, and the Google Home app should also partially work.
03-12-2025 07:22 AM
Thank you! It worked!
03-14-2025 07:22 AM
It works now. I did all the steps. It had trouble while connecting with my internet. You forgot to mention to change the date back to the actual one. Not sure if it is something that everyone has to do but it worked in my case.
03-13-2025 04:36 PM
If and when Google fixes this problem, how do I re-establish app authentication for security reasons? Thanks.
03-13-2025 10:24 PM - edited 03-13-2025 10:24 PM
Disable the bypas device auth
03-14-2025 02:49 PM
Chromecast back on now on original settings and removed Bypass Auth button to off... But will keep Application Manager app incase it happens again! Thanks CHC! 👌
03-13-2025 08:40 PM
No sirve esa app para ios?
03-13-2025 09:20 PM
Oh my God! Finally, it worked! I just did it! It's been hard because I speak French, but I followed your images and it was pretty easy. Thank you so much! And I didn't even have to change the date on my cell phone! The only thing is that Chromecast works only on my cell phone, not on my computer (PC or laptop). At least, I can watch YouTube on my TV by casting it from my phone. It worked with the link someone sent me earlier, because yours didn't work for me. But all your images are exactly what I saw on my device. I'm so happy! I missed my Chromecast a lot since last Sunday! Thank you! 🙂
03-14-2025 06:33 AM
Salve,
quando inserisco la stringa :
com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction
E confermo appare il messaggio di errore :'No Activity Found to handle intent'
03-14-2025 06:54 AM
Realmente escapa a mis posibilidades tecnicas, trato de hacer lo que indican pero nada sale como tiene que salir, activity manager me pide abrir una cuenta en ingles, yo no entiendo ingles y el traductor no lo toma, es realmente muy complicado todo. Porque no pensaran en personas normales sin demasiados conocimientos del tema. Piden verificaciones a cada instante , codigos, qr, es muy dificil esto
03-14-2025 08:54 AM
Infinite grazie.. funziona!
03-14-2025 11:49 AM
My google Chromecast has been updated automatically in Spain and its working again, without doing anything.
03-14-2025 04:00 PM
It worked,,, using android 11 for Chromecast audio.
03-14-2025 05:09 PM
Thanks, It helped me fix the factory reset. It won't let me stream to the TV, but at least it's connected to Wi-Fi again! Now I just have to wait for Google to fix it.
03-14-2025 07:45 PM
What about the current issue also telling this "Chromecast manufactured for a different country"
03-15-2025 08:59 AM
It worksssssssssssss!
Thanks.
03-16-2025 06:14 AM
Thank you for this I also fixed the problem ,but differently (gen 2)....I changed the date on my android phone to 7th March , it connected to my factory reset chrome cast,and updated , after a little patience it connected . I had to set date and time back to automatic and then reboot my phone for it to fully work . But touch wood ...so far it's working
Very happy ,didn't realise I lived this device so much after not being able to use it for a week !!
Hope this helps.
03-16-2025 03:21 PM
How to change de date ?? I am french to so i don't all understand......thanks
10-17-2025 08:36 PM
If you’re having trouble with Chromecast authentication or can’t cast from your Android device, here’s what usually helps (using the GUI method):
Reconnect to the same Wi-Fi network — Make sure both your Android phone and Chromecast are connected to the same network.
Update Google Home — Go to the Play Store and ensure your Google Home app is updated to the latest version.
Restart everything — Reboot your Chromecast, your phone, and your router.
Re-authenticate — Open the Google Home app → tap on your Chromecast device → select Settings → Recognition & sharing → Guest mode and toggle it off/on to refresh authentication.
Clear cached data — Go to Settings → Apps → Google Home → Storage → Clear cache & data.
Test casting — Try casting again from apps like YouTube or Spotify to verify everything is working.
I had a similar issue before, and after following these steps, my Chromecast started working perfectly again. By the way, if you’re exploring entertainment apps, you might want to check out Castle APK, which provides a smooth streaming experience and works well with casting once everything’s properly configured.
12-13-2025 09:41 AM
This is a really helpful fix for Chromecast authentication issues, especially for Android users who rely on casting for daily streaming. When casting fails, it usually breaks the whole experience, whether you’re mirroring your screen or casting directly from apps like OnStream APK. Steps like these make Android casting far more reliable. Thanks for sharing a practical solution.
