Flood light
k9byron
We installed a nest floodlight Camara in our backyard by the gazebo area where we hang out and the floodlight turns on when anyone blinks! We can seem to shut it off in the app without it popping right back on and blinding everyone.
Is there a way to pause the flood light?
David_K
Sure thing! Try these steps:
  1. Open the Google Home app.
  2. Tap your camera.
  3. Tap the settings cog at the top right > What turns on the floodlight.
  4. Tap the switch to turn Motion off.
You can follow those same steps to turn it back on when you're ready.
