12-01-2023 12:17 AM
I have a second generation Nest Thermostat which does not seem to be always switching to Away when nobody is at home. This is very wasteful of energy. Is there anything I can do or is it something to do with the sensors on the thermostat?
12-05-2023 10:53 AM - edited 12-05-2023 10:53 AM
Hi hatos,
Thanks for reaching out. I'm sorry for the delay and for the trouble this may have caused you. I'd like to help. To confirm, in what country are you located?
Check out this guide:
Let me know how it goes.
12-14-2023 10:39 PM
Thank you. We don't rely on mobile devices. Normally it just switches to away when nobody is at home, presumably because the sensor picks up there is no activity. It has been working fine & it was working over the last week but then it stopped working again last night. There are no other devices on the account. The device is always online. It does not usually go into Eco mode when someone is at home. We are based in the UK.
Thank You
12-20-2023 01:53 AM
Thanks for all the information provided. By any chance, in the Nest app, do you see any warning signs or errors in the Home/Away Assist section?
12-23-2023 12:45 AM
Hi there, just checking in with you. Did you manage to check our last message?
12-23-2023 04:53 AM
Sorry for the delay. No there are no warning signs or errors. It sometimes switches to Away sometimes it does not. I can't discern any pattern.
12-26-2023 02:01 AM
Got it. Did you manage to check if the address is set correctly on the app?
01-02-2024 02:22 AM
Thank you for your message. For Security reasons we just have the postcode which is the only field required. Hope this answers your question
12-31-2023 12:53 AM
Hi there, just checking in with you. Did you manage to check the last message?
