My device is not installable and I do not have a barcode or even a code to add a Google Nest Hub dev
ayad
لا استطيع تنصيب الجهاز ولا املك باركود او كود لكوكل نيس هب
David_K
Are you using the original power supply and adapter that came with your device? Try these steps depending on which model you have:
Nest Hub (1st gen)
  1. Plug in the device to a different power source then reboot the device (unplug the power cord, leave it unplugged for 1 minute, then plug the power cord back in).
  2. If the issue persists, put the device in recovery mode with these steps:
    • Unplug the power cord.
    • Hold down the volume buttons and plug in the power cord at the same time.
    • Wait for the device to turn on.
    • Release the volume buttons.
  3. Once the device is in recovery mode, on the back of the device, press and hold both volume buttons together for about 10 seconds.
Nest Hub (2nd gen)
  1. Try plugging in the device to a different power source.
  2. Attempt a factory data reset. On the back of the device, press and hold both volume buttons together for 10 seconds.
Nest Hub Max
  2. Attempt a factory data reset. On the back of the device, press and hold both volume buttons together for about 10 seconds.
  3. If the issue persists, put the device in recovery mode with these steps:
  4. Once the device is in recovery mode, press and hold both volume buttons for 10 seconds.
If the device resets successfully, displays don't use a barcode or QR code. Follow these steps:
Set up your Google Nest or Home speaker or display - Google Nest Help
Juni
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
Juni
Hello there,
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
LovelyM
Hello everyone,
@David_K, thank you for providing assistance.
@ayad, I'm checking in to see if you still need help. Please tell me if you have other questions or concerns. I want to make sure you're all good now.
Lovely
