Nest Wifi Point as Speaker
HomeOwner
Hello, I had Nest Wifi before and now I switched to Nest Pro. I am aware that the old Nest Wifi Points cannot be added as additional wifi points as they are not compatible. However, I am trying to find out if I can use this as a standalone speaker without joining it to the mesh. I tried resetting the device and add it through Google home app but it only tries to add it as another wifi point and fails but not as a speaker. I wish it can just be used as a speaker. Any ideas anyone?
David_K
You can only have 1 Wifi network per home structure. To use your Wifi point as a standalone speaker, you'd need to set it up in a separate home in the app than your Nest Wifi Pro.
Share a home and devices in the Google Home app - Google Nest Help
Alex_S
Thanks for the help, @David_K.
@HomeOwner, I wanted to follow up and see if you are still in need of any help. Have you had the chance to try the suggestion above? If yes, how is it?
Alex
LovelyM
Hello HomeOwner,
We know it has been a while, but we want to ensure that everything is covered on your end. Please inform us if you still need a helping hand.
Sincerely,
Lovely
LovelyM
Hey HomeOwner,
It's been a few days since your last reply — we're going to lock the thread within 24 hours. If you have further concerns, please feel free to create a new post.
Lovely
