a month ago
Currently I can tell Google to turn on a light for a set time: "Hey Google turn on the bedroom light for ten minutes" and it works fine.
Is it possible to set an automation to do the same? For example so I can say "Bed 10" and the bedroom light goes on, and ten minutes later goes off, or "Bed 30" and it's on for 30 minutes.
a month ago - last edited a month ago
What would be even better if the custom phrase was "turn on light for 10 minutes" and you could say for example "Hey Google, Light Ten" to any speaker in a Room and only that light/s would turn on for 10 minutes.
But from another Room's speaker you would have to state the light's unique name or the "Light in [Room name]"
Use something like this in the Google Script Editor (you need to join the public preview if you haven't already).
metadata:
description: Turn on bedroom light for 10 minutes
automations:
- starters:
- type: assistant.event.OkGoogle
eventData: query
is: Bed 10
actions:
- type: device.command.OnOff
devices:
- Ceiling light - Bedroom
on: true
- type: time.delay
for: 10min
devices:
on: false
a month ago
Thanks! That worked perfectly.
