Nest hub max
Kevin1234
If I have 2 nest hub max's  in 2 separate rooms am I able to link it both to my home? Eg: I'll go to the living room and say "hey google turn on lights" then go to the 2nd nest in my bedroom and say "hey google turn off lights" will this work? Obviously the closer one will hear me and respond but is it even possible to link 2 units to one home and get them to communicate?
Thanks
David_K
Absolutely, simply setup both devices in the same home.
GBD
@David_K  is correct but depending on your setup, Google assistant can require you to be more specific in your commands. For example, when you use the command "Hey Google, turn on/off the lights" to the device in the  living room, Google assistant will only turn off the lights that have been placed into the living room in the Google Home app. If you instead say "Hey Google, turn on/off all the lights" it will turn on/off all the lights in the home.
Kevin1234
Yes of course I understand that, I was more asking if I can have 2 central hub devices that will control the exactly home in 2 didnt locations in the house created on google home.
