Why does nest not allow less than 30mins hot water
Michael1966
Why does nest not allow less than 30mins hot water setting? We’re all under significant pressure (understandably) to use less gas, but the ability set the time less than 30mins is not helping! Anybody else as frustrated?
ByronP
Hi Michael1966,
Thank you for posting here in the community. I'm sorry that your Nest thermostat can only get the hot water for 30 minutes. I understand how frustrating it is when you can't set up your desired time frame. Help's here.
Please review the following information about domestic hot water control; there are a few options and troubleshooting to try to isolate the issue. Also, please review this important article and learn about Eco Temperature and how to change settings. There are a few tips to help you out to change the temperature time frame settings.
Let me know if you need more assistance.
Byron
