09-11-2021 08:00 AM
I have a FIOS G3100 router with separate named 2.4GHz band, and 2 3200 Extenders, and everything was working fine until a brief power outage of the router power strip, which included the Nest hub among others, while shifting over to a UPS. It was less than 10 sec. Poorly planned I know. Everything else came back ok. However the Nests did not.
I have already tried a logical reset of the router, and a complete power off 30 sec.
What should I try next?
09-11-2021 05:33 PM
No PW change, probably no channel change since the router was only unplugged for a few secs. I fixed it with the shotgun approach you were suggesting.
Removed all 4 logical devices from the nest home app. Deleted the nest app. Reset all 4 physical devices to factory (held down big button for ~15 sec, until it starts to recite the firmware version, then release and wait for reset). Reinstall the nest. Add back all the physical devices one by one using the app.
09-11-2021 04:03 PM
Did anything change on your network? Ie , password , name, channel, etc? If no, my suggestion is to reset the four protect devices from scratch .
09-11-2021 05:33 PM
09-21-2021 11:49 AM
Hey Robert170,
I just wanted to reach out and see if you are still in need of any help? Please let me know if you have any questions from here.
09-24-2021 12:11 PM
Hey all,
It's been a few days since the last reply. I am going to lock the thread at this time and if you have any questions, please feel free to create a new post.
