Battery draining rapidly on Nest Protect Smoke + Co Alarm
mgh
I received my Nest Protect 2nd Gen Smoke + Co Alarm three months ago and have already gone through three sets of batteries, including two set of the recommended lithium batteries.  Mine is a refurbished unit and I thought this might be the problem.  However, it seems to be a common problem with this device.  Any suggestions?
HelpfulGoogle
The batteries should last much longer than that. Something to check is if you have the Pathlight turned on, and the brightness setting. I would recommend during this off on the battery unit but if you want it on, try lowering the brightness.
GarrettDS
Have a great day.
Garrett DS
Hilary
Community Manager (Admin)
Hey Folks
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
Hilary
