Binding Nest Protect (wired) in Ring alarm system
itsthomas
Can I bind the Nest Protect - Smoke Alarm and Carbon Monoxide Detector (Wired) in the Ring alarm system as follow?:
If the Ring alarm system is on Disamred, it should deactivate the Nest Protect.
And if the Ring alarm system is on Home or Away mode, it should activate the Nest Protect.
Thanks
6 REPLIES 6
David_K
As far as I'm aware, there are no integrations for Nest Protect that would allow you to do that unfortunately.
zoeuvre
@itsthomas, thanks for reaching out to us and for showing interest in our Nest Protect being integrated with Ring Alarm system. I hope you've already gotten the answer you're looking for from what @David_K mentioned. Also, you can learn more about this by checking out this article.
Please let us know if you still have questions or concerns, as we'll be willing to assist you more.
I appreciate your help, @David_K
Is it possible to connect Google Nest Protect (gen 2) to Amazon Alexa?
I'd like to enable and disable the Nest Protect using Alexa routines.
zoeuvre
Hi itsthomas,
I'll merge this thread with the main post, where all the updates will be posted, so we can communicate effectively. You can follow the main thread for news because this one will be locked automatically once merged.
All the best,
zoeuvre
Hi itsthomas,
I wanted to check and see if you are still in need of any help. Please let me know, as I would be happy to assist, and answer any questions you may have.
zoeuvre
We haven't heard from you in a while, so we'll be locking this thread if there is no update within 24 hours. If you run into any more issues in the future, please feel free to create a new thread.
