08-17-2023 07:58 PM
I've had Nest protect for a while now, so when the batteries died, I replaced them. I got another warning within the month to replace again. I then saw that they needed the Energizer Ultimate Lithium batteries. I bought some and put in the new ones...but after a nest check, it said to replace them with Lithium batteries...but they are... After messing around with the alarm longer and just about to through it at a wall...as a last shot, I pressed down on the button until it reset...you know like they say, if indoot, reboot...I then deleted the entire device from my network and reinstalled it, that worked. Showed batteries were fine after that. Just wanted to share that with you all, as this seems to be an issue going round. I hope this helps!
08-20-2023 08:40 PM
Hey Trishb,
That’s awesome! I’m glad to hear that your issue has been resolved. Thanks for sharing your resolution with the Community. I appreciate people who share their thoughts and experiences to help other Community members.
Feel free to reach out if you have any other questions in the future.
Lance
08-21-2023 01:43 PM
how do you delete the device from the network and reinstall it?
08-21-2023 01:56 PM
Hello edknight,
Thanks for chiming in. To remove and add back your Nest Protect from the Nest app, just follow these steps:
Lance
