11-05-2022 01:58 PM
I just purchased a home that has 6 Nest Protects. The previous owner told me nothing about them and probably did not even remove them from his account. I just want them to function as detectors for now. 4 of them have a small green power light on. The other 2 do not. I replaced the batteries in one of them today and it seems to work fine but there is still no green power light. Anyone know why? They may not be 2nd Generation. I'm just guessing at that.
11-05-2022 02:02 PM
Does it show you any light? Like blue?
11-05-2022 02:04 PM
It showed the blue circle for a while after putting the new batteries in. Is that what you mean? Otherwise there is no light on.
11-05-2022 02:13 PM - edited 11-05-2022 02:15 PM
Yes, that's right. I'm guessing you're just about to add those devices to the nest app right? or have you already tried?
11-07-2022 03:59 AM
Sorry I'm getting back to you days later. I found out that when a Nest Protect is wired, it will show the small green light. If it is a battery one it will not. Two of the Nest Protects that were left are battery ones and the other four are wired. Thanks for your help.
11-09-2022 09:30 AM
Thank you for the assistance, @Anonymous.
@Kushyomon, I know it has been a while, but I wanted to ensure that everything is covered here.
How is your Nest Protects doing now? Still need our help? I did find a helpful article with some steps for troubleshooting the Nest Protect lights and sounds.
Please let me know if that helps.
11-12-2022 09:46 AM
Hi Kushyomon,
I'm checking back in. Were you able to do the steps from the link? I'd be glad to hear from you — I'd like to make sure everything is working.
11-13-2022 04:15 PM
We haven't heard any updates from you. I'll go ahead and lock this thread in 24 hours. If you happen to have the same concern feel free to reach us out here or start a new thread.
Thanks for the help here, Mark.
