09-12-2024 05:46 PM
Hello
I’ve a bunch of nest protects which all claim to work and all pass the check up tests.
however when we recently had smoke in the kitchen from a grill fire, the alarm said it was going to sound but then didn’t. We just had a yellow ring on the nearest detector which we had to presss to clear. Is this expected? I was expecting a full alarm to sound.
many thanks
09-13-2024 01:42 AM
Hiya!
The nest protect is designed to determine different types of fire and knows difference between steam and smoke to reduce false alarms. Typically, the nest protect will issue a warning/pre-alarm such as 'Possible Smoke in Kitchen', and if a full fire is noticed then it will say 'Heads up their smoke, sounding the alarm' which then should trigger an alarm if the sensors inside detect it's a fire. If the app is showing you the detector is fine, it should be working. But if you feel as it isn't working then you could try two things:
Let us know how you get on,
- Autumn
10-11-2024 10:33 AM
If the level of smoke should have warranted a full alarm, instead of a heads up there's smoke, report this issue to the Consumer Product Safety Commission as failure to alarm is a commonly reported issue that Google has failed to address or acknowledge internally. https://www.saferproducts.gov/IncidentReporting
