10-05-2021 08:04 PM
I have two Nest Protect smoke alarms that no longer connect to WiFi after the we had the 2G Google Fiber upgrade, either manually or through the Nest app. I know they only work on 2.4GHz. Does Google Fiber 2G support 2.4Ghz WiFi? If so, how can I get them to connect to it. If not, does that mean they're obsolete?
11-04-2021 12:20 PM
Hey Dhouse77,
Sorry for the late reply. I wanted to follow up and ensure you are good to go. Please let me know if you are still having trouble connecting the device to the Wi-Fi, as I would be happy to take a closer look and assist you further.
11-08-2021 01:50 PM
Hey Dhouse77,
I want to ensure you are good to go, and everything is working properly. Please let me know if you are still having trouble, as I will be locking the thread in 24 hours due to inactivity.
11-08-2021 02:12 PM
I'm sorry but I thought I had already replied. It must not had gone through. No, they are not working as designed. They are currently working as conventional smoke detectors. They do detect smoke. They also work with each other inside the property. If you test one then the other will also get tested automatically. However, they will not connect to or with the app. It shows no internet connection.
11-09-2021 09:43 AM
Hey Dhouse77,
I am sorry to hear you are still having issues with the device not connecting to the Wi-Fi. I am not an expert when it comes to Fiber, but I was able to find an article that could be of help. From what it sounds like, you may need to log into your Wi-Fi settings, and configure the settings for the devices. Please let me know if that helped out.
11-11-2021 09:27 PM
I did look at you link. However, I really don't think that solves my issue. That link is just instructions on how to create a new SSID for 5ghz rather than carrying over the same SSID from the original 2.4ghz network. It doesn't really address connecting the Google Nest (2.4ghz) onto the new 5ghz network.
01-19-2022 10:33 AM
Just wanted to see if you still needed help. Please let us know if you have any other questions or concerns.
Garrett DS
11-11-2021 12:37 PM - edited 11-11-2021 12:38 PM
Hey Dhouse77,
Please let me know if you are still having trouble, as I want to ensure you are good to go.
