01-06-2024 11:39 AM
Hi there. I have 120V wired Nest Protect smoke and CO detectors. When I connect them to my home’s wiring (black, green, yellow, red) the nest app indicates there’s no power going into the unit (yellow light on the app only). everything else seems to be working. I tried pretty much every combination of wiring to connect the white and black connectors but nothing seems to work.
Question 1: does anyone know which colors to connect (I don’t have a white wire from the wall)
Question 2: if the unit is not receiving power, how long will the backup batteries last? In other words: can my wired device operate as a wireless device (albeit with the need to replace the batteries or recharge the unit more frequently)?
thank you so much!
01-09-2024 04:35 PM
Hey Avida,
Thanks for reaching out to the Community. I’d be happy to help you with your questions about Nest Protect. Let’s check them out.
All the best,
Lance
